Extreme cold -50 antifreeze
skennelly
Member Posts: 2,196 ✭✭✭✭
Lots of people who used -50 antifreeze are freaking out. Sure glad I go -100.
I know it won't get cold enough even for -50 but you never know. I'd probably be worried.
-50
-100
-1 a billion
one thing that is common is they don’t expand but rather gel.
i also never understood why engine needs to be kept with antifreeze during the lay up months.
if you want use it
if you want use it
flush it and drain it
bing bango
http://newcontent.westmarine.com/documents/pdfs/OwnersManuals/BOATS_OUTBOARDS/Antifreeze136V5.pdf
Andy.
drain the block and manifolds
run the boat on the hose till thermostat cracked open plus some
drain again
I would call this a flush
i would follow by putting 5 gal pink via drive and call it a day.
now I don’t even bother
I just drain and back flush with pink via hoses
My wife also went to Washington High, class of '75. Then Iowa State. I just heard a young man from Cedar Rapids, Kennedy High grad, froze to death at the University of Iowa. Very sad.
Andy
