Docking ropes!
PitterPatter
Member Posts: 23 ✭
I want to get new rope for my 96 Fiesta Vee 300. I will be ordering in bulk. What size do you guys recommend? What is the largest these cletes will allow? One more question: what is the difference between nylon braided you get at a local supply store and nylon marine rope? Thank you in advance for your input.
Double-braided as LaRea noted above. 1/2" is lots.
Docking lines are 2/3rds boat length, spring lines = 1 boat length.
West Marine: 1/8" of line diameter for every 9' of boat length. Larger lines will wear longer but stretch less.
I used snubbers on ALL lines mooring and spring.
What is a rope? What is a line? What is the difference? Many boaters think that these two words are interchangeable--that a rope is a line and a line is a rope. This is not true.
Rope is unemployed cordage. In other words, when it is in a coil and has not been assigned a job, it is just a rope.
On the other hand, when you prepare a rope for a specific task, it becomes employed and is a line. The line is labeled by the job it performs; for example, anchor line, dock line, fender line, etc.
For more information on ropes and lines, see our "Making Ropes Into Lines" e-Lesson. Learn how ropes are made, the different types of rope, what size and length to use for which lines on your boat, how to care for them, when to replace, how to prepare lines with eye-splicing, whipping and backsplicing, and much more is covered in the e-Lesson.............. Just say'n........LOL
