Manifolds and Risers
RansnanRansnan Member Posts: 81 ✭✭
Getting ready to replace the manifold and risers on our 5.7 Horizons any recommendations, is one kind better than another?
    Get OEM
    Manifolds? You said Horizon salt water should not effect them?
    Get a couple pieces of threaded rod to put them on . put 2 rods in the head slide the manifold on then start 2 of the bolts and take out the rods for the other 2 bolts. that way your not trying to hold it up and get the bolts started.
    Used some after market ones with a friend a couple years ago and the socket for the spark plug would not fit on.
    Thanks, i didnt know if there was something better than OEM or not
    rasburyrasbury Member Posts: 8,262 ✭✭✭✭✭
    I did after market elbows..fresh water cooled so no need to change manifold and the risers were good to. They elbows were half the cost..just can't find where I got them ..
    Rasbury, mine is fresh water cooled as well, when i tried to put it in 2 weeks ago, i couldn't get the port motor started, ended up needing a new starter, the Marina said they would install me a new one, got a call from them , was told i had antifreeze in one side of the cylinders. Was told for 2k they would replace the risers and manifolds, i told them i would do it myself and here i am looking for information
    I am absolutely no expert on this for sure- but and I'm not sure we are on the same page...I have a closed cooling system which means I have no water going through the manifold-only coolant throughout the motor itself. My raw water only cools my power steering cooler, and my heat exchanger. I don't have the cool fuel module either. So I have about the simplest cooling system over the complicated ones on newer motors and I'm just fine with that. So my manifolds really don't get the abuse- only the risers and the elbows where the raw water goes into the exhaust. I was amazed that the elbows were in as bad a shape as they were but the risers were OK- maybe it's the water mixing right there at the elbow or something. I can try to find the ones I bought as again, even if I had to buy the risers and manifolds with the elbows, they would have been half the price. They were highly recommended to me- all the holes for mounting stuff were in the same spot etc. Good quality work from China.
    Fredwarner1.net is where I bought my stuff no problem...
