Water Distribution Housing Replacement 2011 Rinker 260
kjlambrix
Member Posts: 11 ✭✭
I have a 2011 Rinker 260 EC with a 350 Mag. Does anyone know if the plastic water distribution housing on the front lower port side of the engine can be changed while the boat is in the water or does it need to be changed out of water? I apparently have a small crack in mine that is leaking periodically. Thank you.
