Water from Shower into Salon
Chennupe1
Member Posts: 5 ✭✭
Hello everyone, I am "hopefully" a soon to be 2004 342 FV owner, however during the sea trial, there were some issues found, some minor, but one specifically an "indoor" plumbing issue. The water from the shower did not drain into the shower pump, but seems to be seeping from under the shower floor into the salon, behind/adjacent to the steps. Not sure if this is a hose failure and if so, how do I access the hose? Could clog drain cause water seepage into the salon? Any schematics of the shower discharge system available. Thanks for any help offered.
where did you get your replacement pump? Do you have a part number?
Thanks,
9000
they are pretty much generic
@zaverin1 is right, they are fairly generic.
I had a leak as well but it was the plumbing, not the drain. It was running underneath the shower and wicking into the carpet in the mid-berth storage.
https://www.fisheriessupply.com/attwood-shower-sump-lid/001001668
