Courtesy lightning
Does anyone know how many courtesy lights they are in a 2002 342. The lights closest to the floor..thanks
cruising on 6. tw0s
2 in the bathroom
2 in the arch
3 in the cockpit
1 on the transom
1 on top of the arch for anchoring
Is this a trick question are you watching me walk around and count the lights.
And if you don't have a good wire stripper, this job might be your excuse to buy one.
If the gauge is too small, sometimes I double back the wire (bend it over itself, and feed into the crimp. I hated working with a solder gun so close to the appointments ... asking for trouble. They have these nice butt crimps now that have an insulation material that is heat shrink ... which is cool. You crimp and then heat shrink to water tight, but it also makes everything that much stronger of a connection ... got them at Home Depot.
