*UPDATED* 2005 Fiesta Vee 270 water seeping up through forward bilge pump and shower sump holes.
Hivolt
Member Posts: 3 ✭
I have a new to me 2005 270 and have been in the process of replacing the shower sump (not working) and forward bilge and float switch (preventatively)
The bilge was nasty as the shower sump had overflowed and had moldy water sitting in the bilge along with dirt and debris so I've been decontaminating it a few minutes at a time here and there. Every time I'd go back to it I had noticed a little brown water in the bilge, I just figured it was the bilge pump hoses letting a little water back in as I have been wet sanding that side of the boat.
Today I finally got around to installing the new sump and pump and had the same bit of water int he bilge again but this time I removed the screws that I had temporarily put back into the holes while I was cleaning and noticed water percolating up out of them. A pretty substantial amount too. I knew there was a piece of plywood under there so I took a half inch drill bit and drilled out the holes to investigate and the hole at the lowest point started practically gushing water out of it. In the last half hour I have emptied close to a pint out of the bilge and it still continues to come. The plywood is also saturated where the other holes were drilled.
What could have caused this? The boat has pretty bad boat pox and some of them have burst, could that have saturated the hull? My worst nightmare is that being the cause. The boat also had a rub rail leak for a long time that I just remedied that would leak down along the starboard cabin wall, soak the carpet and leak into the storage compartments under the bench seat.
Post edited by Hivolt on
You didn't mention a survey. Hoping you had one done, might have a fall back then.
I have narrowed it down to either the air conditioner coolant seacock or the toilet seacock. I blasted them with water for a while on a hunch and got a little trickle down into the bilge between the hull and the glass that was laminated to strengthen the bilge and the seacock area. Very poor work from the factory it looks like.
Hopefully I dodge a bullet, Anything I should be on the lookout for regarding water anywhere else?
