342 fresh water tank leak
DanW
Member Posts: 66 ✭✭
Hello,
I have a 2002 342 and recently developed a leak at the fresh water tank. I’m not sure if the tank itself is leaking or it’s leaking where the hose connects from the tank to the pump. I searched this forum and YouTube and see how to dismantle the aft cabin to access the tank. But does anyone know if there is a way to get to the pump connection to make sure it didn’t come loose before I completely tear apart the cabin? I tried to reach my arm over the bulkhead from the engine room, but couldn’t reach far enough. I see there’s an access hatch under the ice maker, but that doesn’t look like I would be able to reach far enough either.
Thanks,
Dan
Thanks,
Dan
2002 Rinker 342 Fiesta Vee
1998 Regal 2100 LSR
1998 Regal 2100 LSR
Update.....here is the link to my youtube video
https://www.youtube.com/watch?v=W_q8jW_EdZ0
i saw the you tube video. It’s a fantastic video and I think it’s the same for the 2002 model. Thanks for making it. Hopefully, it’s just a loose connection and I don’t have to tear apart the cabin.
Dan
1998 Regal 2100 LSR
Additionally, the tank isn’t holding water. Fill it up and it’s empty by morning. The pump isn’t running though which why I suspect the leak is before the fresh water pump. I’m hoping it’s a hose fitting and not the tank itself though.
Dan
1998 Regal 2100 LSR
