Does anyone have the led drain plug lights
cls10105
Member Posts: 352 ✭✭
If you do i was wondering your thoughts on them and the brand. Thanks guys
cruising on 6. tw0s
Best Answer
Lake_Bum Member Posts: 918 ✭✭✭✭It is decent lighting on the water. No chance of leaks is what I love about it!
I went with lots of LED lighting mounted underneath my swim platform. It's not quite as bright as the transom mounted style, but there is ZERO chance for a leak from the setup!
Those are BRIGHT. And pricey.
Yaa I know, not supposed to run with them on....
https://firewatermarine.com/products/100w-8000-lumen-blue-garboard-led-boat-drain-plug-light-marine-34-12-npt
I pull my jet boat up on an ezdock, I fear pulling on and off may hit the protruding lights. The dual drain plugs on my scarab are 1" off the hull bottom. I'm a worrier by nature 😬
