Tundra refrigerator latch replacement
I have a Tundra T22ac fridge in our 2004 FV270 that needs a new door latch. Can't seem to find it on the net or at any RV stores. Maybe Dometic bought them out? Any solid leads or a part number and supplier would be appreciated.
Thanks, Mike
    jhortajhorta Member Posts: 90 ✭✭
    I know Great Lakes Skipper has a few Tundra replacement parts for rinkers in the OEM section.  Not sure if your part is there, but I have found a few "random" replacement parts from this site.
    French, Thx. Also got that PDF from Westmarine who didn't have a resource for the handle.
    Also tried Ebay which has a host of closures that seem similar but not quite there.
    J, GLS didn't have a similar type handle either Thx.
    Maybe there's a specific contact person at Rinker who would be a good lead?
    I'll also turn my hat around tonight and put my fabricator/engineer skills to work.
    edited January 2015
    :) Www.coastalclimatecontrol.com  Mike, worth a call to these guys. Good luck. RY
    RamkerRamker Member Posts: 32
    Did you ever find a replacement?
    '03 Rinker 312 Fiesta Vee
    Ram- this guy has not been on the forum for a few years.....and sold his boat.
    lupsterlupster Member Posts: 1
    Any one could give direction need to replace T22Ac frig  any replacement brands  that fit correctly  thank you 2004 vista 312 could send me email lupster51@aol.com and advice would be appreciated
    Welcome to the forum Lupster. If you search that model on the forum you’ll see that a few of us have replaced it. I found that the Vitrofrigo C62 fit perfectly where my 22 used to be. Recommend comparing dimensions found online to the dimensions you got when you pulled your fridge. Good luck
