Windless only goes down.
rasbury
Member Posts: 8,855 ✭✭✭✭✭
First, where does the term windless come from or is that even right?
So, out on the water and was hanging on the lake doing some cleaning...windless has only been used a few times. The up and down switch was replaced after I got the boat. The anchor deployed fine when I stopped but when I got ready to leave-zip. It would still go down. I grabbed the wrench (which I have never used) to manually wind it and could not budge it either way. There must be some sort of a release? And some sort of a "switch" to reverse the motor to wind up?
Having to dismantle to lube is a pain and a job for me for winter I think.
Hang on, you're in Florida - afternoon job
do you mean the nut that sticks out the side, where you would put the tool on to turn it manually? I put the tool on there and it would not budge up or down....guess I have to spend some time with it.....sigh, something else to learn from scratch!
First off you will read that parts are no longer available and the replacement windlass that is recommended is $700.
I fixed mine for $22, same exact symptoms.
The easiest way is to remove it from the boat.
Turn the breaker off, remove the small access panel under the mirror at the front of the forward bed. Unbolt the 3 13mm nuts that mount the windlass, there are also a few wire straps that you will need to remove, once you have them removed you should have enough slack in the wire for it to reach through the round access hole. Cut the wires and be sure to lease enough slack so you can splice back together. Now go to the top of the boat and secure the chain or rode to the cleat above the windlass, you will need to remove the anchor and now you can remove the chain/rode from the pulley and lift the windlass out.
Now that you have the motor out grab the small gear on the output shaft with a small pair of channellocks, also grab the end cap of the output shaft and turn counterclockwise. Once the end cap is removed you will be able to unscrew the gear.
Now take the two 10mm bolts off that hold the starter together and remove the starter nose cone, inside the nose cone is o one way thrush bearing that is you problem. Remove it by driving it out with a 19mm socket and replace with this:
https://www.amazon.com/gp/product/B007D31QF0/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
reassemble with some fresh grease and you should be good to go.
If you need any greater detail just let me know.
good luck!
What's a bilut?
Glad to hear you got it. Every weekend I'm going over the windshield to drop/retrieve anchor by hand and imagine what life must be like for you guys and your buttons!!!
@PickleRick I have buttons but still head up and over to unhook/hook the safety lanyard I tie the anchor rode off with.
That windlass gear ever let's go I don't want an anchor and 50 feet of chain under the boat at speed.
Glad it's working for ya Ras
