Engine cuts out randomly over ~20mph - RESOLVED!!!
binduni
Member Posts: 22 ✭
I have a 2002 Rinker 212 BR with the Mercruiser 5.0 MPI that we bought new. Absolutely love this boat! A few years ago it developed an issue of the engine cutting out on plane. Here is the best description I can provide:
- Will idle in gear (put put as we call it) all day long
- Once on plane (20mph or so) it may cruise for an hour or 5 minutes before cutting out. Read: it cuts out at random moments
- When I say "cut out" it's like the key was turned off
- There is NO audible alarm when this happens
- The good news is it restarts every time very easily. Shift to neutral, turn off key, and restart
- I have had a shop spend hours on this with no solution
Has anyone experienced this? And if so, has anyone been able to fix it??
Thanks for the help!
Bought new in Coeur d'Alene Idaho. It's really my dog's boat....
Post edited by binduni on
You're welcome to substitute bee for any other insects or trash that could be found in a fuel tank. In a lawn equipment shop i see lots of insects in fuel tanks from gas cans
Fault codes.... well, the shop I brought it to said "no fault codes" but not sure they even scanned it. I don't have a scan tool but am thinking it would be worthwhile to spend the $500 (I restore classic cars and am a firm believer in the right tool for the job!)
I don't think this has coil packs but I'll check. If it doesn't, I never thought of a faulty coil! Could be....
I've thought the same thing about the fuel pressure, but the shop said "it was fine" with no details. Have I mentioned I won't use that shop anymore? Thinking a scan tool will report if there was a low/high pressure issue.
And I had the same thought about a piece of crud in the fuel tank - had this issue on a car. It's a 40 gallon tank though and will require a lot of pump out or use before I can pull the tank to check.
Also investigating a ground or short issue near the tach. Forgot to mention the tach goes flaky once in a while but we have not been able to connect it reading strangely to a cut out occurrence.
Thanks again the ideas! Keep em coming....
When on plane are you smooth cruising or some bumps/chop? Thinking loose connection maybe, does it have a safety cutoff like some do (I think for Canada). Bayliner had one as did boat another I helped someone with and while not needed here it was faulty.
Im not sure in your case you can read fuel pressures via ecu? There may be a provision in the fuel rail where you can install a fuel pressure gauge? If so autozone or other car place probably has a rental gauge.
Im more carb oriented than efi, i just try to apply my diagnostics to the efi systems.
As icoultha says it cold be a short. Ive seen a shop throw hours of diagnosis on a 4.3 vortec just for me to get lucky and find a leaky heater core hose spraying onto the dizzy at normal running temps, shorting the ignition module.
Ive also seen bad corrosion at coil wires. A good visual could go a long way, cleaning and checking any electrical connection along the way.
I do have a few electrical gremlins that I believe are unrelated - 12v power socket doesn't work, and the tach still reads wonky. Oil pressure is good @ 40-50 lbs, temp steady @ 140ish. Like I mentioned before, it will start right up after cutting out.
I'm also wondering if the emergency cutoff switch would go bad? Can test next I;'m out.
With boat on incline hill bow up like plane position carefully remove fuel fill cap then blow in fuel tank. You or a helper should feel air move out vent.
Vent tubes should gently slant all the way up to the vent. Screens should be in vent outlet but bugs will nest in any little opening they can get in.
@PickleRick I like what you're proposing! I have not traced the vent lines, and honestly don't even know where the vent outlet is. I believe both fuel pumps are external to the tank and could kill both theories (plugged vent / debri in the tank) with an external tank.
It'll be a few weeks before I can test but will report back my findings. If anyone has pics of the vent lines, that would help me a lot.
Thanks all!
At times venting issues can be seen during fuel ups as the fuel fill hose will keep burping and takes forever to fill up.
good luck
Art
Also, I found the coil specs in case anyone was interested:
Any time i get ahold of a an old set of jumper cables with busted clamps i think to myself yay extra grounds
you say "on plane" could be five minutes, could be an hour...
i wager your outdrive needs to be aligned, along with a new gimbal bearing.
try this: take it up to plane speeds, but 'plow'- keep the leg deep, or only trim 'slightly'. do NOT trim it out as you normally would.
think of it like a lawn mower... or a torque converter at stall speeds and not being able to release... the engine dies due to resistance it can't overcome. it's that simple.
the 'trim' trick ought to tell you something.
For my mercury i use an old bar bell bar for initial alignment (1 inch, an old broom handle works) and then a cheap eBay 45 dollar alignment tool for final alignment. Works every well, just make sure your have it all the way pressed when checking alignment.
I could duplicate it easily after I pegged it, and simply stayed out of that trim range heading back to dock... A pull of out drive, a quick alignment, a swap of gimbal bearing, reinstall of outdrive (perhaps an hour total) and never saw it again.
I have the skills to do this but have never it (pull of out drive, a quick alignment, a swap of gimbal bearing, reinstall of outdrive ) - any special tools I need or tips to offer?
A slide hammer with slide ring for removing gimball bearing if needed. Slide ring can be made with flat washers and nut, google home made gimball removal tool and you'll see what others made pics and video. Slide hammer can be rented from autoparts store.
If massively out of alignment in depth analysis needs to go into as to why, rotten core, collapesed rear mounts, bad front mounts, rare but possible bad coupler
For removing and reinstalling drive i can do it solo with aid of engine hoist. 2 decent strength people can do it by hand @100 lbs. My dad and i have removed them together by hand. This summer both of us had to reinstall solo at different times he used a chain fall on a frame i used engine hoist. Chainfall wouldn't have worked for me because of swim platform.
ive also made cradles out of piano dollys and 2x4 so i literally rolled the outdrive off then back on but these were heavier volvo penta outdrives. Working trailer jack allowed perfect alignment. Also worked well for storage. Piano dolly from harbor freight is 12 bucks and a couple 2x4s and screws. Just need a solid surface to roll
There are some good youtube videos on alpha outdrive removals
Have. Seal kit on hand @ 12 bucks for new seal o ring and gaskets, your gasket will tear.
I use a little dab of black rtv to hold gasket seal and o ring in place during install.
Also good time to do baffles, water pump hose and impeller as well as foot oil. Season is almost over she'll be ready for next season.
Its easy to list all this when it's someone elses money.
how do i know that? because it runs in all but 'full trim'. the bind on the shaft is significant at that point...
also... just so you know, because it's not plainly evident... :
your trim has a 'trailer mode' you must not go above while the engine is running... the switch on the shifter has two positions 'up'... one is half depressed and the drive lifts, the other is full depress and the drive lifts beyond it's limits...
i mention this because if you are unaware of that, you could simply be lifting too high.
