Loss of fridge and ice maker power
caik01
Member Posts: 39 ✭
We just got our boat back from the shop and they fixed a lot of poor electrical connections from the previous owners. We never had issues with our shore power before but not when we plug in our Rinker Fiesta Vee 342 to shore power the AC connection isn't reading and we have no fridge, ice maker, head or radio power. When we fire up the generator everything works. What gives?
https://rinkerboats.vanillacommunities.com/discussion/6282/manual-for-342-electrical-panel
Frig and ice maker plug into an outlet under the trash can in the cockpit. Check they are1: plugged in, and 2: they are switched on! Ice maker switch is center top of the grill under the door (rocker). Frig the thermostat needs to be ‘on’.
The 12v side should be totally independent of the generator running or not.
Does the head not flush and / or not fill with water?
Seems like a lot of random things not working suddenly. Pulling the breaker panel might be in order to check connections and breaker operation.
Glad you found it. That was a fire in waiting.
