Undersized Motors?
PaulZ00
Member Posts: 19 ✭
Hey all. I’ve been having issues with the performance on my 2003 29ft Rinker. Seems to run well, but just doesn’t grab and push the water the way it seems it should. It has twin Merc 4.3’s, 6 cyl with Bravo 3 outdrives. It just really struggles to get on plane and pick up speed. It also seems like the props are fighting each other. Steering gets tough at high rpms and the bow of the boat seems to move all over when it’s under power. Some have suggested that it’s a prop issue. Others think that the motors are way too small for that size boat. Thought I’d bring it here to the people who really know what they’re talking about to see if anyone had any thoughts? Is there any way to improve the “balls” on these motors?
I’d really appreciate anyone’s input.
Thank you.
Thank you.
It seems they slip as in I’m constantly having to push them down or adjust them every five minutes. It seems they don’t stay in a “set” position once I get them where I want them.
As far as trimming the drives, I always leave them all the way down unless I’m going shallow.
I just bought this boat at the beginning of the season and have yet to do a full tune up. I’m not sure when the last time the previous owner may have done it, but it seems to be a fairly well maintained boat.
I think my biggest concern is that it really struggles to get over the hump to even try that unless I have only a couple people on board.
But I’ll be giving that a shot regardless. Thanks again
I also question the bravo 3?
are you sure
The steering thing could be a worn steering pin. If you hold one outdrive still, how much can you move the other one? Shouldn't be more than an inch.
Come have a beer with us and we can figure it out.
The 4x4 props sound like something to look into for sure.
I’ll also check out the hull when I take it out of the water in a couple months.
Did we even have a summer?
Thanks for everyone’s input. I appreciate you guys.
Im sure those where "price point" motors but you certainly dont have price point outdrives
I bet with 2 5.7 motors in the same boat you'd notice better economy at crusing speeds. Even a weak 5.7 puts down more torque than the 4.3. Really not too much of a weight savings between the 2 motors either.
With that being said once its top notch again you'll get on plane just fine. Some people bash the 4.3 but taken care of they last a long time. My only comlaint is they drink fuel like a 5.7
I've seen seen some 25 ft bayliner boats with the 5.0
Granted i love the look of the 2455 bayliner hard tops. Sadly the front windows dont open so that would be unbearable in the south all summer. Ive heard the hulls suck for any off shore fishing due to the more cruiser like dead rise. Looks like a fishing boat, handles like any other 24 cabin cruiser.
The 5.7, okay. A 5.0 is a joke, though.
ON PAPER using the stupid equation that is supposed to determine MPG's but falls flat on its face in the real world, the 305 gets better. in reality, they are usually running higher RPM's and dumping vacuum (loading) which means they're rarely trimmed 'crossing zero' lambda... aka, running rich. so.. not even in the real world is there a use for a 305... it's a head scratcher.
