Moisture Control in cabin over winter
Freddy
Member Posts: 13 ✭
Looking for some advice on the best method/material to use to control/eliminate moisture in the cabin and cockpit over the winter. I am concerned with the fluctuation of temperature creating moisture and mold. Any suggestions would be appreciated.
For the rinker i just keep the door cracked enough so the cats cant get in, im parked under a large metal garage.
Caframo Limited 9406CAABX Stor-Dry 9406 Dehumidifier, Warm Air Circulator Fan, Small, Metallic https://www.amazon.com/dp/B0009L675W/ref=cm_sw_r_cp_apa_i_y.xHDb8ZARRWF
Ray
2006 390
Previous 2000 340
I found Damp Rid at Home Depot. Thanks for the advice. And, BTW, thanks again for letting us tie off to you on the North Shore last Sunday.
