Fridge stopped working after power surge but light come on.
biggrobb30
Member Posts: 5 ✭
I have a Rinker 340. I had a power surge when I turned my generator on and every since then my fridge will not cool. Any ideas on the issue or how to remove it from the V berth?
If it's a dual power fridge have you tried on both DC and AC power?
Also, there has to be something holding the fridge in place. Not seen any marine fridge that didn't have a flange and screw along the outside edge. Maybe there is a trim piece covering the screws.
If I remember correctly, the stove top needs to be removed to get to the screws that hold the fridge in ... as others have indicated, you should check to see if a fuse has blown.
Before I'd do all that, I'd put on shore power and see if the 120V to the fridge is working.
