Fridge stopped working after power surge but light come on.
biggrobb30biggrobb30 Member Posts: 5
edited September 2019 in Rinker Support Q&A
I have a Rinker 340. I had a power surge when I turned my generator on and every since then my fridge will not cool. Any ideas on the issue or how to remove it from the V berth?
    Might pull the fridge (make sure the power is off) and look for fuses on the back.
    If it's a dual power fridge have you tried on both DC and AC power?
    Thanks... No I haven't it's been plugged to shore power every since. I called norcold and they didn't have a freaking clue.
    My cockpit firge had a little 5amp fuse on the back of the fridge.
    Thanks reneechris14 but this is my vee berth and I have no idea how to get behind it. There are no screws in the front
    Are you able to get inside the v-berth?  In my 342 I can remove the cushions, and there are storage tubs that can be removed to allow access inside the v-berth.  Maybe there is a way in like that.
    Also, there has to be something holding the fridge in place.  Not seen any marine fridge that didn't have a flange and screw along the outside edge.  Maybe there is a trim piece covering the screws.
    I removed the tub and  fridge is still boxed in .  I'm wondering if I have to take top of the berth off?
    If it's in a box there should be a way to pull it out from the front.  I'd think someone with a 340 on here would know how to get it removed.  In my case there were screws you could see from the front.
    Liberty44140Liberty44140 Member Posts: 4,332 ✭✭✭✭✭
    If it’s your larger salon fridge their could be two fuses, mine had two on the larger fridge, both in the same panel
    If I remember correctly, the stove top needs to be removed to get to the screws that hold the fridge in ... as others have indicated, you should check to see if a fuse has blown.
    Before I'd do all that, I'd put on shore power and see if the 120V to the fridge is working.
