Battery Isolator
My #2 battery stopped working and I found the center post of the battery isolator is fried.  Please tell me if I messed up....  I was on the hook and on they way back I realized that I didn't exercise battery #2 so I switched it over from #1 to #2 while the engine was running.  Not sure if that's a problem but I think that's when my problems started with #2.
  • aero3113aero3113 Member Posts: 10,032 ✭✭✭✭✭
    I’ve switched from one to two with the engine running multiple times with no issues. I think if you turn it to off with the engine running can cause issues.
    I switch mine from 1 to 2 all the time while running. Just don't turn it off while running
    I also switch while running but careful to cycle through the "both" setting and not "off".
    @dcaffrey - What do you mean by "exercise battery #2"
