Replace icemaker with cabinet - 330/340EC
YYZRC
Member Posts: 5,586 ✭✭✭✭✭
I removed the icemaker and I'd like to replace it with some sort of cabinet. Any recommendations on where I could find something close to the same size as the opening? SSI plastics has a few options but they look a bit cheap.
Thanks!
Thanks!
They also make a nice marine starboard fire extinguisher bracket, pricey but correct. Better than the metal or plastic hangers.
My only complaint is that I ordered the version with the seal, and it's clear that the seal won't actually work to seal the door because of the tolerances. No big deal for my application but I wouldn't spend the $25 on the seal if I did it again.
I've been working away at the cabinet, it should work great but getting it installed will surely be painful.
Happy to send the grill to you along with the ice bin which I will collect next time I'm on the boat. Let me know if you want the door seal or any other parts.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/123973644505
It also appears to be made out of wood
