Fuel Module
Hi Everyone, I have a 2006 350 Mag and when I was changing the oil yesterday I noticed water dripping out of my fuel module. The leak is coming from the bottom hose. I have done a ton of homework on the issue and optional ways to fix. My questions is, does anyone know if this is the GEN III on the 2006(if original) or what model it would be? My mechanic said he needs to take the module out and bore out the connection, which I dont understand if its just a hose fitting that needs to be replaced. Also any advise with fixing this issue? Is this something that can be fixed while the boat is winterized?
Thanks for the help and hope everyone had a great season.
Patrick
06 Rinker 270
06 Rinker 270
I found a lot of good chats about it on our nemesis forum, Club Sea Ray, in which this guy breaks down the options you have for a repair or replacement.
http://www.clubsearay.com/index.php?threads/cool-fuel-3-iiii-raw-water-hose-fitting-repair-method.74356/
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
I believe this is the replacement fitting.
https://www.boats.net/product/mercury/8M2010476
06 Rinker 270
You may want to try the route that reneechris is doing since you have the winter to do it. But, if you are paying someone to do all that, for me, definitely worth just replacing. I hate to have things fail or hold me up in my prime summer boating. I will say I've learned a lot & know I'll never mess with fuel. Just changing the filters always has me triple checking everything.
@reneechris14 would this not work?
06 Rinker 270
06 Rinker 270
Port
