FV270 tri-axle trailer set up and dimensions
TikiHut2TikiHut2 Posts: 1,431 ✭✭✭✭✭
We have a 2004 FV270 that didn't come with a trailer so I found a nice tri-axle and gave it a through rebuild. The upgrade has new springs/shackles, new LED lights and wiring frt-to-back, rebuilt actuator, new stainless disc brakes, new bearings and seals and a fresh set of rubber. The cypress bunks were great so they got new carpet. The trailer had a fine winch post and bow chock and after a few upright bow V-guide prototypes I engineered two carpeted horizontal bow support guides near the keel for simple loading. A new set of upright rear float on guide posts makes this a perfect trailer for a larger boat.
There have been numerous requests for the bunk/guide/winch layout so I assembled all the misc pics and here are the dimensions within a few inches if you are doing a similar sized boat. Critical layout centers around the whole rig balancing on the center axle, the bunks extending to support the transom and the tongue weight on the trailer being around 7-10% of the total rig weight. Bunk width needs to run the length of the flat portion of both strakes.
Trailer tongue length needs to be enough to allow the anchor roller with an anchor in-place to easily clear the truck on launch. Make sure the bow chock and winch will also clear the anchor as the bow will rotate downward on launch. A steep ramp will exacerbate that issue with a bow anchor fouling on a taller winch. Easing the anchor and setting it aside is an extra step but always an option.
I'm sure there's more but I'd add that this is an intermediate/advanced fabrication project for those with the shop and tools to safely tackle the job. Our trailer has greatly expanded our spontaneous cruising range, pulls like it's on rails at 65mph and will stop with safety and assurance in an emergency. Good luck and here's a few of our pics/measurements. Again, not all bow guide mods were adopted in the final version shown at the top.
Hope that helps.
Mike m/v TikiHut
  • bigal6030bigal6030 Posts: 157 ✭✭
    Mike, this will be a great help to me. I picked up tandem axle, 11,000 lb. capacity galvanized EZ Loader trailer and have started on a complete rebuild, new braking system, fenders, rollers, leaf spring. Bunks are 3-1/2"x 10"x 12'-3". Axles are rated at 5200 lbs. each with E rated tires. Trailer was originally for a 30' Cruisers Inc. boat. All said and done I will have about $3000 into it when I am done.
    Home port: Hammond Ind.
  • tk1973tk1973 Posts: 122 ✭✭
    Thanks Mike for this.
    Hoping if if anyone knows if these dimensions will work for the 280 as well? Are they the same hull.
    Tim
  • rasburyrasbury Posts: 8,956 ✭✭✭✭✭
    I have heard from Al that they are different but no clue how much...
  • J3ffJ3ff Posts: 4,229 ✭✭✭✭✭
    Thank you Mike, exactly what is needed over here!
    So your good jeff,? Not sure how that very old thread was pulled into yours. Mike aka tiki hut has not been on the forum in several years. He was my boat buying mentor when we bought out boat and then suddenly disappeared ...have wondered what happened to him.
    all set. going to be working on setting it up later today!
