Tie Rod Ends
2»
    Sure would be exciting for a few minutes!
    Not sure I'd use the word exciting, but it'd be something!  I thought it was bad when I had one drive get stuck in reverse when I was backing out of my slip.  That was a treat...but, having tie rod fail when docking or on plane would be worse.
    edited January 2020
    @Dream_Inn , combine both, your drive gets stuck in reverse, you slam the dock and your tie rod brakes. You put the good drive in forward 😳.
    edited January 2020
    I definitely noticed the little bit of play in my steering but it never bothered me as I knew it was not at the steering pin, drives are tight. Being mechanical a little play is par for the course. Hats off to you for taking steps to tighten it up, nice project and nicely documented here for anyone who is bothered by it.
    Thanks @Liberty44140 , the play I had was way more than the “normal play”. I wish I took a video so I could post a before and after.
    edited January 2020
    mine has all sorts of play in it...you can swing the out drive by hand a lot but I have a new steering pin and it did it before and after...are there no adjustments to the steering cable itself? Boat has 300 hours on it so hard to think it would be stretched or a problem with the cable itself...always have bigger fish to fry it seems to really dig into it.
    @rasbury , check where the pins go through on your steering actuator and attach to the steering arm. The holes on the actuator can wear also.
    Not sure if this is what your actuator looks like, but you can see the pins I’m talking about.
    Yes...I need to get down there when someone is turning the wheel.. it is annoying!
    I received the new tie rod yesterday. I had to cut 6 inches off for it to match the original measurement. (The 92020A2 kit adjusts from 30”-46”, my measurement was 40” center to center). The old pins in the new holes have the smallest bit of movement in them now. The machine shop told me that the pins were slightly worn also (they measured them with a micrometer when they were at the shop). I have new pins on order.
    The new tie rod is in (with old pins) and I would say it took care of 75% of the play in the drive. I set my phone up and took a video of the actuator while I moved the drive back and forth. The rest of the play is at the holes for the pin in the actuator. Hopefully when I receive the new pins it will take car of that, if not, I’ll think about replacing the actuator.
