Docking a Twin Sterndrive
aero3113
Member Posts: 9,590 ✭✭✭✭✭
Since my 330 is my first twin engine boat, I’ve been reading up and watching videos. This is the first time I’m hearing of the thumb method, very helpful.
https://youtu.be/F2TNpfvn6QA
The pivot point is about the front of your motors and the wheel has to be strait first. Get a indicator you can stick on your wheel, that will help.
I do like the thumbs idea. I've always thought of it more like driving a tank.
https://youtu.be/d5X9iFkGoDU
I bet you'll have more of an adjustment period getting used to the added windage and legnth/width than the steering. The steering will be much better than your old single screw.
If you dont have a boat hook, grab one until you're comforable bumping your fenders against the dock so you just need to get within 6 ft reaching distance and extra 6 ft push off.
@Stodge is right about parallel canal parking, its a real pita especially if your seawall neighbors leave way too much slack on their lines. Id kill for a twin screw when we stay on the canals, island winds rarely stop.
On the down side, I discovered this boat was much more wind sensitive than I anticipated. Although you supposedly have more control docking against a wind, I much prefer having wind broadside and push me into dock. When I'm against the wind, by the time my wife can get off the swim platform, I'm often losing the bow. She'll have the spring cleat line in her hand, but it's a heavy boat for her to pull back in if it gets to far away.
I feel like my 235 would make a good dingy for most of you guys. I bet my nautical mpgs would be amazing if i snatched up to some davits on the back your one of your yachts!
As much as i love the almost salty look of a hard top, those arches just look timeless. I blame it on being a child of the 80s, i blame it on Miami Vice.
inboards with rudders are a different story
In a few weekends youll dock like a pro compared to your single screw.
You have to understand the difference between single props (like inboards) and counter-rotating props (like Bravo 3). Single props produce prop-walk that moves the stern to one side or the other. Counter-rotating props don't do that, so there's a different method to move the stern.
For example, to quickly move the stern to port: Wheel to stbd and bump one/both engines in forward gear. Or, wheel to port and bump one/both engines in reverse gear. It's the same thing you'd do on a single-engine boat.
It takes time and the only way to get better is to actually do it in a form of repetition . The more times you do it the better you will get. I often say that every docking is different ie current, wind, traffic and then there's the onboard brother in law that wants to move around the boat and get in your way just as you are backing into your slip.
Yes sit down and be quiet and don't move.
