vhf with gps vs vhf tied to chart plotter
skennelly
Member Posts: 2,196 ✭✭✭✭
I'm looking to upgrade my VHF this season. Looking at the GX2200 and the GX2000..there's about $125 different between the 2 because of built in GPS.
Should I get the built in GPS for redundancy or would I be satisfied hooking to my chart plotter and save the $125?
Also I have multiple cell phones onboard capable of GPS.
Having a VHF with DSC will allow the distress function to work without needed a plotter. Now if you want to see other peoples locations using DSC, then you'll want to connect your plotter and VHF.
http://myboatsgear.com/2017/01/08/position-polling/
And am I dreaming or do I recall there is a regulatory change coming that will require all VHF radios to have GPS/DSC in future?
A DSC capable VHF radio can be hooked to your GPS. Steps as follows:
1) Ensure your VHF has DSC capability. The red button (usually with a little flap over it to prevent accidental activiation) is a dead giveaway.
2) Apply for a MMSI (Marine Mobile Service Identifier) that is a unique 9 digit number that in the U.S. can be obtained from Boat US.
Link here: https://www.boatus.com/MMSI/MMSI/Home
In Canada they come from the Federal Government Transport Canada department.
In Canada you must prove you have a valid RROC (Restricted Radio Operator's Certificate) with DSC endorsement proving you've taken the course and passed. Should be an automatic requirement for a power boat license in my opinion, but is not.
The MMSI is then programmed into your radio. Must be done with care because with most radio's it will only accept it once, and once entered cannot be erased except by sending radio back to the factory.
3) Hook the radio and GPS together by finding the two NMEA output wires on the GPS and connecting to the NMEA input wires on the radio. Refer to the manuals for your equipment as the colour of the wires can vary.
4) Check the baud rate setting on both units to be sure set to the same so they can talk to each other.
Once enabled, when you push and hold the DSC button for a few seconds it activates an electronic signal that can be heard by boats in the vicinity as well as the Coast Guard and also sends out your coordinates from the GPS.
The advantage is that in a fast paced incident like a fire or sinking the signal goes out without you having to make a radio call and wait for a response.
I have friend's MMSI numbers in my VHF "phone book" so I can locate them or send them my location when we're on the lake.
If it's for entry, in the past an radio could only accept up to 2 or 3 different MMSI number, and after that, it had to go back to the factory for a reset. This was in case someone put in the MMSI number incorrectly. So you may be looking at your spare "oops" corrections.
