2004 342 Fiesta Vee
I’m in the process of buying a 2004 342 Fiesta Vee. What should I look out for? We started the survey and found water in the engine compartment. The port side engine has a hole in the exhaust hose. The bilge pump in the engine compartment is not working and we couldn’t find the second bilge pump that I believe is under the mid berth. We didn’t find a door or hatch to locate the second bilge pump. Any thoughts or suggestions on what I need to be aware of would be greatly appreciated.
Ken Walker 2004 342 Fiesta Vee
hole in the exhaust is not normal but not a deal breaker, I’d ask the seller to replace the exhaust risers and manifolds
In the cabin, check the carpets down near the floor for stains that might indicate water leaks into the cabin. Leaks are a common problem in any boat that age.
And of course, pay close attention to the outdrives for signs of corrosion.
Has the boat been kept in salt water or fresh?
What's the engine/outdrive package?
cdx-ca705m
If I was to replace I would do something different with bluetooth.
JL Audio MBT-RX Bluetooth Audio Receiver https://www.amazon.com/dp/B00MH5CFEU/ref=cm_sw_r_cp_api_i_TsonEb9TBJ9T5
shadowVIRUS, shadow99056, shadow990, helloguru9901 and helloguru990 joined.
I really like the dude with the boat term btw.
Also how are the docking manners of a twin v drive vs twin dp outdrive? How much reversing ability do you sacrifice with the v?
I've heard that docking is easier with V-drives. But even with B3s, a 342 is dead simple to maneuver.
