2003 Merc 350 MAG MPI coolant line
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
This is the hose heading to the exhaust riser, starboard side of engine, comes up from the raw water manifold and splits to each side. Raw water cooled engine.
So this formed hose is no longer available form Mercury, to boot: one end is 3/4" the other 1" (riser side).
Any brilliant ideas on how to replace? No way hose off a coil will bend and not kink to make the turns. I hate to make a cluster of adapters and 'PVC' right angle pieces. Reducing the riser manifold barbed fitting is an option, but guessing I would have to do both sides to balance the flow.
https://public-mercurymarine.sysonline.com/Default.aspx?sysname=NorthAmericacompany=GuestNA_KEY=NA_KEY_VALUElangIF=englangDB=eng
and use your engine serial number to search. That will give you the original complete Merc part number which you may be able to use to cross reference to see if Sierra or another aftermarket outfit has one. I'd be surprised that someone somewhere doesn't have it. You did mention though that Merc doesn't have it so maybe already have the part number. But maybe someone else will find that fiche above to be handy.
Also, there are specialty rad shops that can custom form hoses (think antique and custom car market) that can form hoses but won't likely be cheap.
https://www.amazon.com/MERCURY-Mercury-Quicksilver-32-864508-Hose/dp/B00A8OMLCI
i would still have the issue of the Tee being 3/4” and the barbed pipe fitting into the riser being 1”. So I would have to change both sides to balance flow.
Pic added for clarification
