Does gear oil go bad?
I have some gear oil that is 5 years plus old, maybe more. Is it ok to use or should I buy new? Also, my mechanic was talking me out of mercury gear oil, saying it has had problems in the past. Drawing a blank on what he said was wrong with it. Anyone agree or disagree?
Thank you in advance.
Patrick
06 Rinker 270
06 Rinker 270
I don't know of any issues with mercruiser brand oil but as with any oem oils they usually take bids on suppliers and many times there is an equal or better alternative.
Mercruiser doesn't produce oil. Whoever got the contract for a particular batch refined it.
I wouldnt use 1985 Quaker state oil
But 2005 mobile one, toss it here.
I have some old unopened Texaco metal cans from the 70s
FWIW, I've always used high performance mercury gear lube.
I do like synthetics but i prefer blends. Synthetic is better for bearings/journal surfaces. Conventional motor oil is better for seals/gaskets.
06 Rinker 270
As for older vortec/350 engines and the like i prefer blend. They are more prone to weeping oil but still need the restart lubrication of the synthetics.
My excursion has 235k on the clock, only ever ran dino rotella.
Zero gunk under the valve covers, changed every 5k.
Whenever possible i run dino rotella in anyting i own, i even run the same t4 15w40 in my rinker as i run in my excursion. Also ran it on every motorcycle ive owned from a 75 cb550 to a 2006 Ducati monster. Wet or dry clutch didnt mattrt.
I did go big and buy castor oil 15w40 synthetic blend for the rinker this winter because it was marked down to 18 a gallon. T4 rotellla is usually 16.99
06 Rinker 270
I can't remember how long ago I posted the results of - at the time - true dino oil - that is with no synthetic in it - but in super high temperature situations......which most engines encounter at some point, the dino oil just vaporized.
Every time the "old" dino oils were run hot in an engine they lost return viscosity and ability to provide shear protection. After a few cycles of this you might as well have had dishwater in your engine.
Newer "dino" oils had to have some synthetic added to them to meet EPA mileage requirements and were a bit safer but no where near a quality semi or full synthetic.
As well even the lowliest synthetics smoked the best dino oils in friction tests. This testing was done on a dozen top brands by the Shell Oil labs and other forum members at the time sent in similar reports from some independent labs.
So, no matter how many times you change an inferior oil product you are still using an inferior oil product. For boaters I would say that is just like shuffling the deck chairs on the Titanic. For gamblers I would say that no matter how many times you shuffle a hand full of deuces you still have a hand full of deuces.
So at the very time your engine needs protection you have an inferior product unable to protect it and we haven't even begun to discuss the long term benefits of friction reduction at start-up, anti-friction protection under load and longevity.
I respect all opinions but as a former teacher of advanced chemistry and physics in high school it is just not true to say that dino oil is equal - in ANY way, other than price to synthetic oil.
In fact synthetic oils ramp-up protection as engine conditions deteriorate in an overheat condition or even a spike as they form more comprehensive chain polymers when threatened by high heat - just as they were formulated to do.
Opinions are personal, facts maybe less so.
But my over riding question is - given the cost of engine/drive repairs why would saving a few bucks on oil even be a consideration? To be honest that comment just baffles me!
In newer gm motors they run approx 210 to 220 degrees. In raw water cooled boats 140 to 160 degrees.
Your engine oil will be approximately the same temp as your coolant.
I've yet to see a 4 stroke engine die because of oil failure. Even in a mower running sae hd 30 that hasn't been changed in 3 plus years. All they do is top it off the level.
Dino oil may burn off more quickly than full synthetic but if you're adding more than a quart between 7k changes on a gas motor you have a leak or an internal issue. Some vw/audi engines drank oil between changes and it was a design flaw. Not all engines are designed well, switching to full synthetic can be used as a band aid in some situations.
Under normal every day use (even racing) the oil should never get hot enough in a 4 stroke to break down with proper service intervals.
Different brands use different dye in their mix oils so many times a little visual inspection can tell you what's up before you dig in.
Echo/shindaiwa tech support will tell you running orange stihl mix is a no no. Stihl xp is not officially approved but the warranty techs i have to seek approval on for all warranties give an unofficial A ok.
for and it keeps the power valve cleaner), but I run Dino in some of my stuff too. Maintenece is more important.
I've only seen this issue in the 591, 600 and a few blowers.
My info comes directly from warranty/tech department of my regional factory distributor.
I put a new top end on each one with zero adjustments or repairs to the fuel system aside from pressure testing the fuel hose.
I eliminated all other possible causes before submitting warranty, which is what im required to do if it's Briggs and stratton, kohker, husqvarna, hydro gear, stihl or shindaiwa.
Back in the 70s and 80s 2 cycle mac, poulan and homelite saws all ran 16:1 and you mixed 30wt motor oil with the gas. Today's 2 cycle engines run much hotter and instead of 6000 max rpms they can run 10,000 or more. How well would your truck run at 10,000 rpms non stop for 24 hrs straight? Well a 179 dollar ms170 is rated to do that for about 125 non stop hours.
Things change @69fastback
Across the board, all newer (past 3 to 5 years and newer) major brand 2 cycle equipment will last longer if you run synthetic or synthetic blend oils rather than dino oil. The biggest killer of a 2 stroke air cooled engine is heat.
Calling echo/shindaiwa junk because you need proper rated oil is a very ignorant statement. Our 7.3 power strokes are not junk because they require specially rated oils to prevent gumming of the injectors. My tdi isn't junk because conventional oils will lead to round lobes on the cam shaft (PD engine) synthetic only on a PD engine and some will say only vw rated at that but i like my t5 just fine.
Im sure you are just trying to get a rise out of me but your statement is extremely misleading and could lead someene who reads to ruin a piece of equipment or sway them away from a smarter purchase choice.
Your truck is liquid cooled and your rpms dont turn what todays air cooled 2 cycles turn. You're trying to compare apples to oranges. They are both internal combustion engines, that's about where the similarities stop.
I don't know the egts of a 2 cycle. I do know the carnage caused by using improper mixing oil.
