Stater will not turn over...
rasbury
Member Posts: 8,998 ✭✭✭✭✭
So on the water, no issues...stopped for lunch....hit the key...weak starter turn then zip...plenty of juice on the batteries...no breakers tripped...starter? Had a lot of water in the bielge recently and was worried about this...guages will not come on either so total power shut down...but the Genny will start no I have juice...
So, I know the power goes through the starter and the ground goes to the motor...when you hit the key, power is already there so it's finding a breaker or a ground as the problem ? So for the power to go through, the starter solenoid has to engage when you turn the key on and then as you turn it fully the starter motor starts to turn...that solenoid engaging, does that make the connection then for the + side to go through the rest of the "system"? Like to light up the gauges and the power to the starter motor? I will get one of the breakers...same for the trim to I'm told...
