2007 Rinker 280 EC
The Main Exchange
Member Posts: 280 ✭✭✭
Can some one please explain the battery switches as you enter the cockpit from the swim platform. The rear most switch has 'OFF', 'ON', 'BOTH' the forward one is labeled generator 'OFF', 'ON'. We have a 5kW generator. There are 2 batteries installed and which battery does what? Thank you.
I don't know what's going on the front battery is going bad, new one on order, cruise to the fuel dock, fuel up and no start. Ended up having the starter jumped to start the engine. Any ideas as this is getting frustrating.
Ok. I will give this one a shot. You have 2 batteries. One should be a deep cycle battery that runs everything that is battery powered while you are not connected to shore power. Lights, Refrigerator, Bilge Pumps, etc...Basically all your power while you are away from the dock. The other battery is for starting only. It is not a deep cycle battery but a starting battery. It's sole purpose in life is to start your engine and generator. That's all it does. You can run your lights, refrigerator, bilge pump etc...off your starter battery but it will not last very long. Not designed to do that. So either your starting battery is bad or you are trying to start off the wrong battery. How were the lights when the boat would not start? They should have been strong.
Your battery switch toward the back should be set to "ON". This allows each battery to do what it was designed to do. One just starts the generator and engine. The other runs all the other stuff like your lights. Not sure what to tell you about the 2nd switch. Are you sure it is a battery switch?
Thanks.
OK. On top of the engine starboard side is a fuse black fuse box. The most starboard side fuse is yellow and 20 amps. This is to supply battery voltage directly to the starter. If the starter solenoid becomes dirty inside the contacts may cause a short to ground this in turn blows the fuse. I guess this is a common problem, I now learnt from the previous owner that this fuse blew last year, so I now have 2 spares on board. I have no intention of replacing the starter solenoid at this moment in time but if it becomes a frequent problem I will. I have also replaced the group 24 deep cycle battery with a group 29 deep cycle. Hope this helps.
The boat blew 2 of the big yellow fuses this weekend trying to start the engine. Does anyone know how long it takes to change the starter motor?
