How does this work: Access to just about ANYTHING!
rasbury
Member Posts: 8,263 ✭✭✭✭✭
My GPS turns on and gets a warning that seems to be common from what I googled when the wires to the receiver are bad, but, it is flus mounted and I just don't see any access to this or about anything does not look like you have to take the boat apart to get at it! It is mounted to the left of the steering, How the heck do you get at it? I will get a new receiver and when I pull the old wire out use it to pull the new wire through as I don't see how that would be even possible if not done that way!
Mark is right, check on-line for mounting details for your specific eqt.
While you're in there run out all the anchor line for inspection and make sure that the end of the line is tied off in the hold correctly so it doesn't just run off the end of the bow pulpit some day or worse, come untied if you have it all out in an emergency. ( While it's out measure and paint some 30' distance marks/tags on the rode(from the anchor) so you can easily tell how much is payed out when setting your basic 5to1 scope. I use florescent orange stripes about 3" wide and 6" apart for every 30' with the last one on the chain right where the anchor is barely dragging in the water (5' to the bow roller?) so I can drag it at idle speed for a few seconds to rinse the mud off. just sayin'. Check those shackles and safety wire them while your at it.
You might as well figure out how to pull all of the dash switch/gauge panels (it's very simple but quite a rats nest once inside). You'll be in there from time to time (can we all say/groan Faria gauges in harmony). Undoubtedly the gps has a mount flange behind the display that is accessed behind some trim or from the back after pulling a nearby panel of some sort. Check and clean all the connections while you're in there but be gentle.
Good luck, mike
Good luck.
Hi all....
Could one of you guys that have successfully removed that forward mirror please tell me exactly where the velcro is located. If I need to push, pull or pry I want to do it where the velcro is and hopefully not break the mirror And do you push mirror forward of pull it in the aft direction to disconnect the velcro? Also do the side trim pieces have to come off? I have a loose bolt on the bow roller that I need to tighten and their is no way to reach it thru the 10" inspection hole. I have removed the windless by just going thru the inspection hole and it was a pain but doable, but cannot reach forward bolt on the roller.
Len
Len & Robyn 342 FV Freebird
In addition I also painted a mark on the chain when the anchor is nearly retrieved but still hanging just below the waterline so I can pause to rinse off the goo by backing down for a few seconds before hoisting it into the roller.
I had my windless rebuilt and the tech said the most common reason for failure was trying to haul the weight of the boat forward with the windlass rather than slowly using the engine to move toward the anchor. Secondly was laying at anchor in any wind or especially overnight with the windlass carrying the load rather tying off the rode to a cleat.
Prior to this boat I hadn't had the luxury of a powered windlass and always used the Admiral as a windless but she has assured me in no uncertain terms that there will be no going back...
I'm 6-1" and have to stand on my toes to just barely see the markers as they run over the roller, but it's enough. Otherwise just retrieve until it clanks home or binds and hope the anchor is in the roller. Timing it won't work if the chain-to-rode joint skips at the windlass. I'll often have to pause to let the chain get a bite on the windlass as it transitions from the rode.
Good luck.
Where can I find the tags for the rode?
