270 FV Trailmaster Trailer hub/bearing help
04FV270riverrat
Posts: 268 ✭✭✭
So I had a bearing go out about a mile from my house last winter, I limped it home and let it sit. I started tearing into it today and it looks pretty bad. I think I’m going to need new drums & pads all the way around. Where do I find those?
The problem wheel hub looks like this.
My big problem is the marina is 80 miles away, I have a small local lake about 15 miles away I can probably take the boat to to unload off the trailer if I need to replace this whole axle.
Any info towards finding the bearings/seals is appreciated.
Call these guys.
Also, welding on spring plates is not a huge issue. Get your new axle and your old one and any reputable trialer shop should be able to hook you up.
My sister used to eat dana 35 axle in her yj all the time. I got good at swapping in Cherokee axles.
A bearing that has busted apart leaving the inner race stuck on spindle can be removed by heating one side with a torch then hammer the heated area which will distort it and it will slip right off.
Welding a bead around the outer race will shrink it enough to almost just fall out.Do not burn through!,it don't have to be a "pretty bead"
