Correct Dip Stick Part Number
I ran my engines today. When I shut them down I let them sit and then checked the oil. They haven’t run since I did the oil change in the fall and wanted to make sure the oil level was good. I noticed that the starboard dipstick seemed a little longer than the port side. Sure enough I lined them up together and it is longer! Which one is the correct dipstick!?? The port side part number is 8M2021557 and on the starboard side all I could find was a -9 on it.
Port: 8M2021557
Starboard: -9
Starboard: -9
Mercury Marine Mercruiser OEM Dipstick 861942T9 https://www.amazon.com/dp/B003903TDI/ref=cm_sw_r_cp_api_i_RUGNEb58SR7Z1
http://www.marineengine.com/parts/mercury_marine_parts/sn/1A316620/4442077UU/13884_140
Port SN: 1A316620
Starboard SN: 1A316622
I wonder if the sequencing is different for horizon and thus the big difference in our serial numbers despite same build year?
Do you know how to decode the HIN?
Amarine Made 12V 60W Oil Change Pump Extractor, Oil/Diesel Fluid Pump Extractor Scavenge Oil Change Pump Transfer Suction Transfer Pump + Tubes Truck Rv Boat ATV https://www.amazon.com/dp/B082TNCJP8/ref=cm_sw_r_cp_api_i_aGKNEb0DNNZ6D
Here are the hull code deciphers - Some HINs have a country code before the HIN #
ABC – Manufacturer Identification Code (MIC)
12345 – Manufacturer’s Serial Number
B2 – Manufacture date where the first digit represents the month and the second digit represent the last digit of the year.
A=Jan, B=Feb, C=Mar, D=Apr, E=May, F=Jun, G=Jul, H=Aug, I-Sep, J=Oct, K=Nov, L=Dec
12 – Last 2 digits of the model year
how the heck does a motor end up with the wrong dipstick. That’s weird.
