B3 prop alignment
boatman37
Member Posts: 798 ✭✭✭
So read somewhere before about aligning the B3 props to eliminate vibration. Then remembered reading something about only the 3x3 props need properly aligned? I have the 4x3. Even if I try to align them they change after a few revolutions anyway?
Also, I added grease to the rear cone washer (first washer that goes on). None on anything else other than the shaft and splines. Pretty easy to pull them back off if I need to change something.
https://rinkerboats.vanillacommunities.com/discussion/861/prop-timing-torques-specs
There is no special timing of the props. Service manuals for engines and drives are available from local dealers or by calling our Publications Department at 920-929-5040, option #4. Have your serial number ready when ordering.
Thanks,
James
MerCruiser Consumer Support
2017-00054090
Sent: Friday, April 21, 2017 8:39 AM
To: MERCRUISER CUSTOMER ASSISTANCE <mercruiser.customer.assistance@mercmarine.com>
Subject:
Contact Request:
Address :
City/State :
Zip :
Home Phone :
Work Phone :
Email Address : raybo3@live.com
Serial Number :
Model Number :
Dealer Name :
Boat Manufacturer :
Boat Model :
Contact By : Email
Comments:
I have a twin Bravo 3 drives. My question is do the props have to be "timed/aligned"? If yes is there an online manual for this. Thank you for your help.
Mercury Marine
mercruiser_customer_assistance@mercmarine.com
https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mercurymarine.com&d=DwICAg&c=tjPg1sbLxZ1bjgTYa5hhdw&r=FEQWMy8t0qVEVOymqTeqBMVeLlfR66Wd26pDhpbyAhJy52Gjwpo5ZejkaibZ_Oj7&m=QgsNEbY6VvzuK92b0MB4xtuZmHSs-23Fe4yO09LJ4w0&s=Klr2U2CSt7hoq_R2C1JyFY8t_6PVhoHuQ2JHfIG6eUQ&e=
https://www.youtube.com/watch?v=Zo1l1RncrvI
Install the forward prop.
Rotate it until one blade points up.
Install the rear prop with one blade pointing down. It doesn't matter where the logos are.
Wrong way:
Apparently, if you have the front and rear blades passing through that space at the same time, it creates vibration, or cavitation, or both.
Each one shows counter-rotating props viewed from behind. Any time there are two blades passing each other at the 12 o'clock position, the animation pauses and the blades turn red.
First we have two 3-blade props (3x3) that are aligned incorrectly. You can see that every time a blade of the rear prop passes the top, a blade of the front prop is also there. It happens three times during every revolution.
Now a 3x3 correctly aligned as specified by Merc. You never get both blades passing the top at the same time.
Next is a 4x3 setup (4 blades on the front prop, 3 on the rear). They never line up at the top, although it does get close a couple times.
Actually, it is possible to mis-align a 4x3. You can have two blades line up at the top. However, it only happens once per revolution, and only if you line them up perfectly wrong like this.
(updated the graphics, added cavitation plate and skeg)
