Anchor?
Robs_232
Member Posts: 212 ✭✭✭
I have been reading posts on this forum for a while and have learned a lot. I bought a 2004 Captiva BR 350 Mag with Bravo 3 last fall and the previous owner did not have an anchor. I am trying to figure out what anchor to buy that will fit in the anchor locker in the bow. I have measured what width fluke anchor will fit in the anchor holder and I am struggling to find one that will fit. Any suggestions? I will mostly use the boat in lakes with a mud, clay, or sand bottom. I will also buy a secondary anchor so any recommendations on either would be great.
Robs_232
Best Answers
craigswardmtb
Member Posts: 1,015 ✭✭✭
I luv my rocna. It seems to work and reset in all conditions. It is pretty oblong though so I'm unsure if it would fit your anchor locker. Mine sits in a windlass. -
JoeStang Member Posts: 1,137 ✭✭✭✭
I assume you have a 232?
I have a Danforth 94013 and it BARELY fits in my anchor locker holder. Its worked VERY well in sand & mud for my 276, so I'm sure it'd work very good for your 232.
2013 276 Cuddy ~ 350 MAG / B3
You can also look at Fortress anchors which can be dissassembled for easy storage, but are as good as anything else is sand/mud.
Michael T,
That was my concern when looking at the measurements and what would fit in the locker. I hate to cut off the ends of the stability rod and have an anchor that rolls and not set. I am curious what anchor Rinker sold as standard equipment when the anchor was bought with the boat new or was this dealer discretion. Was it a slip ring anchor or was it a traditional fluke anchor.
Thanks for the info. I think I am going to try the one I mentioned above. If it doesn't work like I think it should I can always use it as my back anchor when it's swim/Miller time. Rob
