Trim tabs not working
MiamiAG
Member Posts: 210 ✭✭
Hi everyone,
First time boat owner question on trim tabs. They are not working.
I have a 2013 290EC and the Lenco trim tab is the model with the rubber pad on the dash. It doesn't have power as it has no lights and the tabs don't work. I need help to fix.
I know enough to first try to see if it's a blown fuse. The fuse in the cockpit isn't popped out. I understand there is another fuse in the wire to the tabs themselves. Unfortunately, I have not been able to find it in the mess of wires down in the engine compartment.
Has anyone had this issue with a similar boat and can point me in the right direction?
Thanks,
Thanks,
Art
Lenco Marine LLC warrants its new products to be free from defects in material and workmanship for the following periods: Trim Tab kits, Switches, and Actuators purchased after April 1st, 2019 have a 5 year warranty. Products purchased prior to April 1st, 2019 are under our original warranty period of 3 years.
thanks!
