I’m in, but.....
aero3113
Member Posts: 8,863 ✭✭✭✭✭
I got dropped in today around 9 am. Low tide was at 11 am. I went out for a run and everything was perfect until I got back to the slip! First line up to the slip was perfect and slowly started backing in. As soon as I got to the front of my slip the boat stopped! Too shallow!! I was able to raise the drives and pull forward then got stuck again in the middle of my marina! This seemed like an extremely low tide for some reason. I was idling for a short period and both engine temperatures started to rise and got an alarm. I shut them down and waited a while. A little while later I started her back up port engine temp was fine and stayed cool, starboard started to overheat again. I waited a while for the tide to rise and was able to get her in the slip. I ran both engines again, I pulled the top drain plug off of the pump on starboard and no suction, I pulled the top plug off of the port pump and there was a good amount of suction. I think sand got sucked in and something jammed up the starboard impeller and spun it on its shaft. I have a impeller kit on order. I don’t have any valves to block off the water so will have to get some wooden dowels to plug up the line when the pump is off. If anyone has changed a pump in the water and have any tips, please let me know!
I pushed her up to 5K and was just over 40 MPH, I didn’t want to push any more but was curious!
It was fun while it lasted!!!!
You should keep a replacement on board. If I had one onboard already I could have saved the time waiting for a tow. From break down to getting back to the dock was about 3 hours cause the wait was so long. Would have been nice to fix it in 30 min and continue my boating day.
This should help
https://youtu.be/rOrlvEypvBM
That's much more involved than Volvo. I used to wish I had Merc but the more I see I am actually very happy with my Volvo especially since I have found ways to source parts much cheaper.
