New noise
Dream_Inn
Member, Moderator Posts: 7,573 mod
So, 2 weekends ago we were out with boat on plane and I was thinking boy she sure sounds nice. We slowed down and pulled in to anchor. I jockeyed around a little and then heard a noise that sounded a little like a helicopter way off in the distance, but it was from the engine room.
Last weekend I decided to stay nearby and not go on plane till I get it fixed. I noticed that at idle, not in gear, I hear the noise from my stbd motor. It's actually from aft of engine and is accentuated when I turn the wheel. I'm thinking maybe the main ujoint at the end of the shaft on the outdrive. I know it wears out if putting drive up too high? Mine is not very old and I don't ever trim drive too high.
Any thoughts? I do have a work order in and should be taking it over on Sunday to drop off.
I should add that it is not very loud and it took a good ear to listen. Definitely not always there either. I greased the coupling, but that didn't help.
@Alswagg - being that the noise is really subtle and just started, do you think a 20 min ride on plane to my mechanic would mess anything up more?
@Alswagg both are the newer sealed gimbals. Thanks guys!
I always keep a spare mounting gasket or two on hand. I seem to tear them less when i have a spare.
Again, the sound is very faint and most may never hear it. I've gotten tuned to hearing this crap and like to jump on getting it fixed right away if possible.
That awkward position of the shaft kills more bearings than likely anything else. I'm not saying thats what killed yours, but it costs many theirs.
Double check what I said about alpha gen 2 and check what a b3 is supposed to be.... but that is where you'd want it set as a high limit.
Now, I do go thru a "cut" or back door that at high tide (when I can't fit under a bridge) I go thru an area that is 3-4 feet deep and maybe 150-200 feet in length. I will put the drives up to maybe 1/2, at most, on my gauges and only at idle. I may do that 10 or so times a year. I've really never raised my drives above that. She sits on a lift and drives are all the way tucked in. They are B-2 drives.
