Autopilot for 290EX
CaledonCruiser
Member Posts: 8 ✭
I have a new Rinker 290 EX (Merc 8.2 and Bravo Three) and want to
install an autopilot, but am getting mixed advice on what type to
install. I have a Simrad GO9 mfd installed from the factory and want a
Simrad autopilot to coordinate with it. One place said the Rinker 290
has mechanical cable steering that is power assisted and recommended the
Simrad Outboard Pilot Cable Steer Pack, while a different dealer
recommended the Simrad AP44 VRF Medium Pack which is recommended for
hydraulic steered sterndrive boats up to 35 ft.
Can
anyone shed advice on what autopilot is recommended for the 290 EX?? Is
the steering cable or hydraulic?? Has anyone installed an autopilot on
the 290 EX?
Unfortunately, the Simrad devices you mentioned won't work with your B3. The first one is for outboard motors, not sterndrives. The second is for hydraulic steering.
Have you looked at Octopus Drives?
https://octopusdrives.com/products/type-r-mechanical-remote-drives/
For what it's worth, here's a thread about my install on a 370. I have a Raymarine nav system. Raymarine doesn't make an actuator for cable steering, so I used an Octopus drive. After three full seasons, it's working perfectly. Zero complaints.
https://rinkerboats.vanillacommunities.com/discussion/6500/autopilot-installation-on-370
Will this be a DIY job, or is a shop installing it?
https://www.simrad-yachting.com/simrad/type/autopilots/drive-units/outboard-pilot-cablesteer-pack/
When I built my AP in 2014, I don't remember seeing anything for cable sterndrives other than the Octopus. I had a Simrad AP installed on my 342 in 2003, but I didn't do the work and can't remember what kind of drive it had.
Heres everything you need:
AP computer - Simrad AC12N (and NMEA2000 network if you dont have one already)
Also, simrad computers have "Virtual Rudder feedback" so nothing is needed for Rudder feedback
AP Compass - Simrad RC42
Drive unit - Octopus Type R
Mine works FANTASTIC!! I love it
You do not need the High Voltage computer. They do make a "Core Pack" with everything you need besides the octopus drive
If Octopus is still delivering those drives as unpainted aluminum castings, consider slapping a coat of paint on it before installation. I wish I had painted mine.
Maybe I'm wrong ...
