New noise
13»
  • Dream_InnDream_Inn Member, Moderator Posts: 7,806 mod
    @YYZRC check alignment first and also gimbal bearings.
  • aero3113aero3113 Member Posts: 9,563 ✭✭✭✭✭
    @YYZRC , how do your props look? I remember when I went on sea trial, I heard a noise that I wasn’t sure if it was the port gimbal bearing or the props. This season the noise is gone with the new Hill props.
  • YYZRCYYZRC Member Posts: 5,357 ✭✭✭✭✭
    Funny you mention props! One starboard prop was damaged and repaired prior to shipping the boat to me. Maybe it’s unbalanced.
    edited June 2020
    If you can narrow down the side, swap the props and see if the sound follows. If you have the tools, you can remove the props in the water, not 100% as easy as swapping them on land though.
  • raybo3raybo3 Administrator Posts: 5,569 admin
    @aero3113 swap the props?? 1 is a left prop and the other is a right prop. Can't swap them the boat would go backwards............lol
    Swap them from drive to drive, doesn’t matter.
    Sorry bro but it matters. Port engine spins in one direction and S/B spins in the other direction.
    I have to disagree on that. Both engines rotate the same direction. If it was inboards, different story. That’s why both engines have the same ID for Vissel View, and you have to change the ID. No difference.
    When I received my new props, nothing was labeled LH or RH turn?
    Motors turn in same direction, drives don’t. My 4 blade big cow props were left and right.
    Any recommendations on a prop wrench for the B3? OEM?
    I definitely agree that our B2 drives rotate different directions.
    There is no difference between port and starboard props on a Bravo 3.
    On a B3 since they counter rotate then the probably are the same direction drives.
    YYZ are you sure that it’s not just rpm out of sync? When rpm is out of sync you will have a totally normal waaaa waaa waaa and speed of the noise depends on how out of sync they are
    @areo3113 I stand corrected. My mind was on a bravo 2 (that's what DI has). You are correct B3s are the same. Sorry for the confusion
    No problem @raybo3 !!
    I have the digital rpm on VV and they were within 25 rpm of each other. Is that enough of a difference to cause vibration and droning?
    no, that is not enough difference to have that symptom.
    yea agree with Dream if you are that close then thats not your noise
  • SpyderwebSpyderweb Member Posts: 947 ✭✭✭
    @YYZRC I bought the OEM this spring.  Heavy expensive thing but does the job.
