Outdrive tilt issue
Outdrive will engage when pushing down, and I hear a click when trying to tilt up but won’t budge. Any ideas?
Patrick
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
maybe another solenoid problem: end of last season I was having issues starting the boat. Turn the key and nothing, not a sound. I keep trying the key and eventually it fires right up. So far this season no issues but I’m guessing I will soon. Starter solenoid?
06 Rinker 270
you all are a wealth of info. Thank you
06 Rinker 270
06 Rinker 270
06 Rinker 270
nope....did it one other time for just a second but then started...last time sat for 30 minutes and then all of sudden the alarms started going off so I knew the ignition had power and fired it up!
I have an 04 FV270 MAG350 mpi 2 years ago started having issues. Turned out the engine computer was on the way out. Eventually died and boat would not start at all
Needed to replace the ECM
Another question that is related. How often do you add oil to the outdrive trim bracket? Does it need to be drained and new oil added?
06 Rinker 270
06 Rinker 270
One side of outdrive has a limit switch so you can't raise above safe height underway- aka the trim switch... the other side has one for your gauge.
Lower your drive all the way... loosen the limit switch (puck on port side of drive) enough to be able to turn it. Raise your B3 23.75" exposed ram... turn the puck until your trim switch won't move it... that simple. Tighten it down. Your drive will now operate with the trim switch but not beyond 23.75" which is safe limit for B3s.
The other side is for the gauge..... and it is a PITA to adjust. Lower drive all the way and turn the puck slowly and slightly until it reads full down on the gauge.... tighten and raise drive... hope the drive reads too on the gauge when you hit the limit, if not, go back and start again.
