New heavy anchor and windlass issue
Spyderweb
Member Posts: 951 ✭✭✭
Installed a new Mattis 35 anchor recently to replace the stock 25# that came with boat. Windlass is the Pro Series 1000. When pulling up the anchor, as the end of the shaft end hits the outer anchor roller, it seems to often catch, and the windlass slips. My 1st question is does this hurt the windlass? Or is this a torque limit built into the windlass to protect the gears? Is this a sign the new anchor is too heavy for the windlass (35# vs. 25#)? At this point, what we're doing is if it won't ride over the roller after a couple of tries, we pull it over the roller manually, then finish with the windlass.
https://www.westmarine.com/buy/lewmar--pro-series-windlass-clutch-nut-lever--10633212
I'd recommend an anchor swivel as well. They are tapered somewhat & glide over the roller pretty good.
BTW you're gonna love the operation of that anchor.
@mattie Agree on the "bit overkill". Anchor was a gift from our kids for Xmas. The Mantus 25 would have been fine for the boating we do. We figured we'd keep it if it fit, and it did. It does look like that taper on the Mantus swivel would help. Currently "out of stock" at West Marine.
thanks guys.
