Mid-Bilge Leak
YYZRCYYZRC Member Posts: 5,357 ✭✭✭✭✭
My mid bilge is filling with water.  I've tracked the source down to the area around the AC thru hull, but I don't think it is the thru hull itself that is leaking.  It wasn't until I saw the pics of @aero3113 underway with the AC discharge that I got thinking that maybe when underway my AC is also picking up water and it's leaking into the mid bilge area.
I did a two hour run today and I sucked at least 5 gallons out of the mid bilge when I got back to the dock.  No idea how often the bilge pump ran during the trip but regardless it's a concerning amount of water.  It was too rough to hand over to the Admiral today, much less to be poking around in the aft cabin.
Has anyone encountered this?
  • aero3113aero3113 Member Posts: 9,562 ✭✭✭✭✭
    edited July 2020
    Checks your clamps or the strainer. Maybe they need to be snugged up.
  • YYZRCYYZRC Member Posts: 5,357 ✭✭✭✭✭
    Next time out I will run with the thru hull closed to see if there's a difference, but we are thinking along the same lines.
    Do you have a photo of that compartment?  Mine has a void in the fiberglass next to the thru hull that looks, well, sloppy.  Once I fix this I'm contemplating filling it with 4200.
    That’s one area I never took a pic of, I’ll have to now!
    If your A/C discharge was injesting water I would assume it leaks while the A/C is on too.
    Check the hose and thru hull for the A/C condensate drainage (if your 330 is set up like that). Also your anchor rode drain/thru hull.  Those thru hulls can crack.
    Discharge isn't an issue.  Everything forward of the head is dry.  I believe water is being forced into the AC pick-up when moving and I've got a leak or loose connection somewhere between the thru hull and the pump.
    Not taking in water when at rest/in slip?
    The strainer is worth looking at, a bad/missing o-ring   Could be a culprit. Cracked water hose could open under pressure and be ‘closed’ by the pump suction too.
    I don't think water is coming in when docked, or if it is, certainly not in the same volume.
    The o-ring is installed on the strainer for sure, but its quite old.  I remember thinking it looked rough.  Cracked hose theory also makes sense.
  • IanIan Member Posts: 2,980 ✭✭✭✭
    Hmm, has me thinking to of a similar observation.
    It was the strainer leaking. I need a new o ring. For now I tightened it with a vise grip.
    Easy fix!  Use some plumbers silicone grease on tne o-ring when you install it. Helps from it getting beat up every time you remove the strainer.
    I had water in my mid bilge last week and I saw the shower sump box was leaking a tiny bit when we used it. Now this week there was more water even not using the shower. I noticed one of the hose clamps for the AC was loose and it had a steady drip so I tightened it up and no more leak.
    Just figured I would mention something in case someone was searching for mid bilge water issues.
