Prop Slip Test
124»
    @jmichels, interesting, what boat was this test on?
    It was a 270FV.
    Those numbers are quite different than the 300mpi. Example: with the 4X3 21 p 3600 rpm is about as slow as you can go and still stay on plane, 28 mph. and a greatly improved hole shot.  But before with the original  3x3 22 p 4000 rpm was about as slow as you could go and stay on plane. It took almost a month to get on plane. LOL Top speed with either prop configuration is 42 mph.
    wm61356 said:
    @Handymans342 - that is interesting. I wonder if they could make a recommendation for my application. I've spoken to a dealer in my area about props but they wouldn't commit to any improvement with 4 blade props and, with the shop I spoke with, once the props have been mounted they wouldn't take them back. The shop you are working with sounds much more reasonable.
    You would have to do a slip test first so they could recommend a prop.
    Thanks JMichels and Handy, for the information. I have a 2009 320 with 5.7 MAG MPI motors coupled to B2 drives with 21 pitch aluminum props that are not cupped. The boat performs well but I would like to get on plane with less bow rise and pick up some efficiency at cruise speed.  Unfortunately, my boat is all tucked away for the winter so a slip test will have to wait until I launch in the spring.
    I think I am the only one on here that has done this test.
    @handymans342 - is it finding out WOT rpm and MPH?
    Yes you need to know your WOT rpm and GPS speed. Do not use dash tachs. Use a laser tach
    Got it. Thanks Handy.
    WM61356.  You have a 320 Rinker or Sea Ray?
    In either case you would likely definately benefit at the very least from stainless props versus aluminum for less distortion and flex.
    my 4x3 props were on my 03 Rinker 270. Worked very well.
    @jmichels - I have a 320 Rinker with B2 drives, only one prop per drive. Sea Ray? What's that? LOL
    How did you get such a late model with B2s?
    The previous owner must have ordered the boat with B2s. I've owned the boat for 4 years. During that time the drives have been bullet proof. Absolutely no corrosion problems.
    Bringing this one back to life. Do these slip numbers sound kosher? All recorded same day same run. 2008 330 with B3 and 22p original props. RPM from VesselView and speed from GPS.
  • rasburyrasbury Member Posts: 8,844 ✭✭✭✭✭
    I'm just  happy my boat goes forward...
    I thought slip would increase with RPM.
  • LaReaLaRea Member, Moderator Posts: 7,989 mod
    Nope.  Once you're on plane, the faster you go, the less prop slip you get.  This is easy to calculate ... similar to some charts I posted a couple months ago.
    I like slippage......
  • PickleRickPickleRick Member Posts: 4,281 ✭✭✭✭✭
    I pitt they say its sloppy outside
    I put in a few gear ratios to see what mine might be.  I have an 18.75 diameter prop.  Says the 2.0 is not possible.  I think the 1.6 looks most realistic, how about you guys?
    @YYZRC those numbers are same as my 342 runs.
    @LaRea will tell you to run fast because less slippage is better fuel economy.
    i run with several props... each having a purpose...
    the ron hill pleasure five, 19p/14.25" is impressive... according to tach and gear ratio, it has single digit slip- like, between 6 and 8%.  on plane, and anywhere from 2250 RPM (where it starts to fall off plane) all the way to max RPM with that prop which is right at 5k RPM... it's good for right at 52mph on slick water... the water cuts right under my seat on the 212 when it's fairly slick surface and trimmed up right.
    a 3 blade 21p stiletto in 14.25" is a pig out of the hole, and though it can push around 60mph at 4800~4900RPM, it's a bit of a..... liar... they are marketed as '21p' and take a hit for out of the hole performance compared to other 21p of the same class... because they're really not 21p at all.... the one i have is 22.5p as measured by a prop shop as 'mean' pitch across the blade... it was 'new out of the box'... the cupping is also significant and the rake is ridiculous... at the bitter end of RPMs, and playing with the trim to maximize RPM, it too is around 8% slip... it struggles to hold plane under 2800RPM and the slipping it significant up until 3600~4000rpm where it bites in and trim can be finessed to the least drag possible.  the bow of the boat is high and the water cuts perhaps a foot to a foot and a half behind my seat on slick surface and trimmed just right...
    between those two, i can get my best economy... the three blade stiletto offers better economy if i get on plane and stay there and above 40mph compared to the five blade trying to do the same thing... however, if there is traffic on the water or i have to drop off plane often- or- i have clear path and can settle the throttle around 3kRPM and cruise, the five blade is far superior in terms of economy.... as an example, i made a 28mile run two weekends in a row now, one with the stiletto and another with the ron hill.. the stiletto impressed as the motor spun it fine and drank 10.5gallons for that run... i didn't know how much difference the five blade would be, but it turns out it only drank a touch over 8 for the exact same route.  fairness, again: i had to drop off plane several times with the 3 blade, where i only came down once i recall when it was the five blades turn.
    the third screw i run is a Fury... 21p... it has some stupid huge vents and i can't find the plugs for them (if i ever had them in the first place)... the diameter is smaller- perhaps 14.125 and the cupping nor rake isn't as significant as the stiletto nor the ron hill.. i'd likely have more purpose for this prop if i could plug those vents, and because i can easily 'blow it out' coming out of the hole and can blow it out a bit if i punch it hard while on plane- i guess the exhaust pressure breaks the water tension for a second or two?.... now, in fairness, if i had to select JUST one prop i 'may' be inclined to choose this one IF i could plug those vents effectively... bonus: i don't have exhaust bellows, i just have a tube... the only place this prop is disadvantaged is from lower speeds and below plane where the tube is shoved into the lower unit.. trimmed up (north of 40ish MPH) it's free and clear..
    the Ron Hill 5 blade is far superior overall... i just keep the stiletto around for when i want to run fast... that happens sometimes... okay, a lot.
    i share all of that just to say- there is no perfect prop for everything... there is a perfect prop for it's perfect application... that said? anything over 15% slip from 75% throttle up needs to be addressed. at least with a non-duo outdrive...... also a little tidbit: my ratio is 1.62:1, which is why i can spin that stiletto nearing 5k RPMs (that and some help on the valve train with rollers and a little higher ratio rockers than the stock 1.5:1's).
