It goes with the device so if they did the MMSI transfers to you.
Yes and no. An MMSI stays with the radio. The web site for MMSI allows you to do a transfer, but AFAIK the PO has to do it. You can try going to the MMSI site and seeing if there is a "claim" function. I believe when I traded in my center console last year I went on the MMSI site and released the MMSI I had put into the radio.
Never heard of them charging for MMSI, but then I've been a member since I've owned a boat.
You can have more than one MMSI number and you can also use the same MMSI number for multiple units.
I understand what you're saying but to clarify, the MMSI registration includes a vessel description and registration info so if they have to come looking for you they know what to look for. So you'd have to be careful with multiple MMSI's to tie them to each vessel. As far as I know anyway.
I have different MMSI for different things. One for the 342, one for the center console and one for the hand-held. Same owner info, different boat info.
I'd want to make sure the release/transfer of MMSI took place. While the boat info may not change, the name could, and the contact info (to include contacts ashore) would.
While you can use the same MMSI in multiple things, you lose some of the value of the info collected in the MMSI system.
Same issue here in Canada too. Legally you need the course and license to operate the radio but not to own it or have it in the boat. So they have to catch you using it which rarely happens. Most idiots justify it with the idea that it's only there for an emergency and if they make a mayday call with no licence they won't be charged. But temptation always takes hold and they end up using it like a CB. Rant over.
https://www.cps-ecp.ca/course-catalog/ Course only offered in class by the Canadian Powerboat and Sailing Squadron and the book is proprietary to them and they tightly control the contents. Test is both written and verbal with various radio scenarios . Edit: the course description pretty much shows what they cover. I enjoyed it and learned quite a bit. They even covered a bit of navigation, I think as a teaser to the Nav courses they also offer.
Willhound is right, no online course for the VHF radio license (ROC). There's a practical, they basically make you spell out your last name using the phonetic alphabet, and then simulate a mayday or a panpan call.
From what I remember, ANYONE who has a radio, can listen in, and actually by law is required to monitor channel 16. But to hail on VHF you need the ROC. In an emergency (mayday, not panpan), people would normally chose to risk a fine and call the mayday, in the event they do not have a ROC ...
Having a ROC is a good idea if you want to transient in different ports, as you can hail the marina office before you enter and get the reservation in action (they'll tell you what doc to slip at, etc.).
Since that course is not readily available to US citizens I take it we're exempt. I've used my VHF to hail marinas on the Canadian side. Nobody waggled a finger at me.
No one will pick it up if you are hailing properly and using the radio properly. It's the guys that are like "Larry, can you hear me ... are you fishing, what depth? Oh by the way, we brought hotdogs for lunch, you guys doing anything later on? How's the kids?" and of course on Channel 16.
But the law would state that in Canadian water you need a ROC to use the radio, no matter what country you were born in.
You can have more than one MMSI.
also is the gx2000/2200 the go to or are there other models you recommend?
06 Rinker 270
gx2000 requires that you tie it into your chartplotter to get GPS so there is some wiring there...but it should be easy to wire up.
Doesn’t the hailer require you to install a hailer horn?
thanks for the tips.
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
