Underpowered boats
Why do manufacturers install engines on boats that make them clearly underpowered?
How do they trial these boats and say...yeah that's acceptable?
I'm sick of having 4 adults and 3 kids on board and the boat being a pig.
I question whether the Rinker hull designs are as good as competitors with respect to performance/planing.
The weight range of the 270 is near the limits for the single b3 leg as well ad the 5.7.
My 28ft, much heavier bayliner, also had that same set up as an option. The b3 was at its limits for a single leg and it took the 5.7 everything she had to cruise on plane. The drives and engines didn't live long.
Everything will need to be perfect to perform properly. Dont get any more fuel than what you need. Any soggy wood core adds WEIGHT!. Go light on the water tank. Keep the head pumped.
If you don't use it every time you go out take it off the boat. Stow anyting you can forward. You'd be amazed at the amount of junk a small fishing boat gathers, your 270 has 50x the storage.
The hill marine props help with stern lift which is what you need but only once you make sure all else is top notch.
Use trim tabs to get on plane. Tell kids or anyone on board to go forward and look for rocks while getting on plane. Trim accordingly for best rpm to stay on plane.
The engine needs to be in tip top shape. As she ages, the engine wears and the hp drops you'll lose power.
That boat would benefit from a big block or a nice LS engine. A 383 like what @J3ff is running also makes it seem like a new boat.
Bayliner, searay, rinker, nearly all mass produced boats sold cheaper packages because that's what buyers wanted.
We have one member on there with twin 4.3s attached to b3s. I'd have rather gotten 5.7s.and B2s myself. Budget engines but top shelf drives...made no sense. But when all is running well i bet he has just as much fun as the guy with twin 300hp diesels.
How clean is the bottom? I will tell you that when ours gets covered in growth even with the 496 it's a slug.
The props will help but id want to make sure shes in top top shape before an 1100 prop set. Now if you're going to keep the boat as a forever boat then the 4x4 props are a must.
Also, a leak down test is much better than a compression test. To tdc, center stroke and then bdc on each cyliner if you want to get ocd about it.
Their customer service and tech savvy is pretty well documented across many forums.
You get a few negative posts but some people put nice new props on engines that are not running properly then want to blame the prop supplier because it didnt do what they expected it to do.
I'm pretty sure I have 24P on it.
https://www.ebay.com/itm/322074057892
It's the reason I found this forum, looking everywhere to solve the 1 mile to get on plane problem. Bite the bullet, get some 4 blade props. I pulled water skier's after that. But never would even attempt it with stock props.
Boat dealers' order boat's to there specs,
