2008 330EC Waeco Fridge Low Voltage Cut Off (LVCO)
pinkish_panther
Member Posts: 15 ✭
I believe I have read everything I can find on this topic both for boats and RVs.
I am experiencing what seems to be a common problem with Waeco units, even with my house battery voltage near 13V when the fridge attempts to start the compressor the voltage drops below the LVCO (around 10.2V) causing it to short cycle and not get to the expected temperature.
My house batteries are brand new - 2 x 6V 235Ah Deep Cycle.
I’ve taken a separate battery and wired it directly to the fridge and it works as expected so I tend to agree with the majority who believe its a wiring issue - but I believe the wiring is original to my 330EC.
I tried to trace the power cables back to the panel. My DC panel has a dedicated breaker for the cockpit fridge but doesn’t seem to have one for the cabin. There is a cabin breaker with a large wire on it but I do not know where the fridge wire goes. I was able to get as far as the engine compartment then it joins another wrapped bundle of wires and seems to disappear.
Anyone have any suggestions?
I’m thinking I may use one of the unused breakers and cut the wire in the engine compartment and wire the fridge directly to the unused breaker but that will only cover the positive side, not sure if it will be enough...
All thoughts are welcome.
Thanks in advance.
Thanks in advance.
Sorry for that non-answer, but it's all I have.
I was concerned I’d have to do the negative wire as well which would have been a pain since that one really gets lost.
Note that there is still a .1 V drop at the fridge compared to the batteries directly (it was .3 with the other wire), and when the compressor is running the voltage reading at the fridge drops more than 1V - but as long as that isn’t 10.2V it keeps going.
