Any of you replace your generator before?
MiamiAG
Member Posts: 210 ✭✭
Is it true you need to remove the engine to make room to remove and replace the generator?
Thanks,
Art
Thanks,
Art
Says it seems to be an issue with the electricals and he would need to completely remove it a redo the rotor.
Is it in an insulated case?
As life would have it, or "this being a boat...", I need to take off the heat exchanger to clean it because I'm getting too hot at full throttle. If I do need to replace the generator, now would be a good time because removing the heat exchanger would likely open up enough room to remove it as one piece.
Of course, the $6,000 for a new geny and the $2,000 to clean the heat exchanger may force me to delay this endeavor until next season.
The rebuilt many pto clutches for us in the past.
kohler?
He had replaced the generator side several times, mostly due to corrosion issues caused by the salty air over the years.
I wouldn't call it quiet but it was impressive that he had never done any major work to the engine in 20 years.
It was quieter than my "quiet" generac inverter generator while running my ac. Quiet generators are not so quiet with a heavy load on them.
Ive not worked on kohler diesels. Does kohler even make their own diesel engines? I work on Kubota diesels all the time. All the equipment my boss owns is bobcat or kubota and all run Kubota engines. Like most diesels, the pre maintenance is kept up they live long trouble free lives.
The same logic would suggest that we would all be better off with a Honda 9.9 mounted on the swim platform instead of our problematic stern drives
From a cost perspective, sure, a 2200 can't be beat. But you've got to store the 2200 when not in use, you're running wires to hook it up every time and you're storing gas on board somewhere. Sounds like a lot of hassle, especially in Florida where you can boat all year long.
And to @LaRea's comment, my genny has also been reliable, save for a $15 duck bill valve and some maintenance (plugs, impeller, etc). Knock on wood.
I see them used commercially all the time. They take some abuse. I refuse to work on the ones that will be used for tailgating at Clemson games.
I like the idea of an inboard as I could run the AC while under way. I won't do that with more than idle speeds using my generac(near identical to the Honda)
During the last hurricane that hit the Keys, power was out for quite some time and water got into the bilge and stayed there for a long time. This seems to have caused rust damage to several components and now I see it has happened to the generator.
Curiously, the generator started up just fine several times after the hurricane but recently seems to have run into the problems I listed above. Whether it was damage from saltwater or simply not running it, it now seems to have these electrical problems...
I guess the above is indication that I really don't need a genny the way I boat but we are doing more long-trip cruises now and a genny is a backup that I do feel I need.
