SOLVED after seven years: Outdrive trim works at idle, but not when on plane
LaRea
Posts: 8,069 mod
[EDIT: This problem was caused by a trim sender that was not installed correctly. Here are the key facts:
* Mercruiser systems with DTS have an outdrive trim limit that is linked to engine speed.
* If the engine is above 2750 RPM, the software does not allow trimming the outdrive up past a certain level (I think 50%).
* My port drive trim sender was not installed correctly. It was reading 54% when the drive was all the way down.
* Therefore, although the trim worked fine at idle, it would not operate at high RPM.
[END EDIT]
This problem inherited from the original owner is still unsolved after 7 years. Somebody please help me!
Once during winter layup, I had two heavy guys hang on the outdrive. The drive was able to lift them both off the ground easily. Why can't it lift when I'm planing?
This problem is bugging the crap out of me. Besides the obvious fuel impact of not being able to properly trim the drives, my inner OCD self just HATES having something on the boat that doesn't work.
Here's the original thread.
https://rinkerboats.vanillacommunities.com/discussion/3380/outdrive-trim-works-at-idle-but-not-when-on-plane
[END EDIT]
- 2008 370 with Merc 496, Bravo 3 and DTS
- At idle speeds, both drives trim up and down and sound normal
- After the boat is on plane, the stbd drive will trim up, but the port drive will not
- It doesn't matter how long I press the trim button
- The problem was originally on the starboard drive
- When I swapped trim pumps, the problem moved with the pump to the port side
- Parts I have replaced on port side: trim pump, up solenoid, hydraulic cylinders
- Converted both drives to digital trim indicators
If I'm planing with both drives all the way down, the pitch and roll angles are normal, but the port drive won't budge. If I trim the stbd drive up a little, the boat rolls to starboard, so I have to level it with trim tabs. That works, to a point.
When I spent $500 on a new pump, I was *sure* that was the problem. When I then replaced the up solenoid, I was *positive* it would work.
@YYZRC nailed it; the trim limiter for some reason came out of adjustment. No reason, but after adjusting it all was fine.
For sure, I'll adjust them when I haul out for the winter.
Looking at the VV display with engines off, I moved each drive through its full range of motion. On the starboard drive, the range is [1.5 - 100.0]. But on the misbehaving port drive, the range is [54.9 - 100.0]. When the drive is physically trimmed all the way down, the lowest reading is 54.9.
Now, these numbers appear to be percents. They are not the raw sensor ADC counts. Merc says raw counts can only be read by a Merc dealership, and the range would be something like [100 - 650]. The VV shows whatever the engine computer spits out over SmartCraft.
Apparently, the engine computer thinks that the port drive never goes lower than halfway down. If that's true, then once I get above 2750 RPM, it would say "I refuse to raise the drive any higher at this speed."
I'm scheduling a short haul to check my trim sensor.
Not sure if you feel like a swim, but I've adjusted mine in water very easily. Turn the drives so the starboard side is exposed and then all you need is a Phillips screwdriver to release the screws and rotate slightly. A tiny rotation results in a significant change in the reading - I had the admiral at the helm shouting the readings to me as I rotated the sender (ignition on but engine not running). Snorkel recommended.
Here's what I would do ... at idle RAISE both up and leave them up, then floor the gas (safely) ... so if you can get that problematic drive to LOWER.
My theory is, it should lower, but not trim up ... that means the pump isn't providing enough pressure to overcome the force it needs to lift the bow out of the water.
