Can't trim down.
RiverRat232
Member Posts: 596 ✭✭✭
Took the boat out for a spin today and the trim started acting up. It wouldn't trim down for some reason. I pressed the button and either the pump didn't run or I could hear it running but the drive didn't trim down. Ideas?
I have to agree with the other guys if you're not hearing it run.
It won't be far from the back of the engine on either side. Usually between the batteries and the transom.
If it is stuck it will be easier for a heavy friend to push on it after you swap it out. Will be hard to bump it up and down quickly from a crouched army crawl position, possible but not comfortable.
Just like any solenoid with a constant hot make sure the power is cut before removing to avoid fun sparks.
The water tank side sat starboard and needed to be kept half full to counter the weight on the port side
