Shrinkage!
Pat310Pat310 Member Posts: 603 ✭✭✭
Found replacement for the windshield screw cover on my 2003 310 that had shrunk with age and was allowing water in by the screws and thought I would share. https://www.steelerubber.com/insert-trim-70-3813-340
Also available on Amazon from this company. Reasonable price at $3.49 a foot. Fit well. We will see how it holds up.
  • Aqua_AuraAqua_Aura Member Posts: 2,702 ✭✭✭✭✭
    That side profile on the website looks different than my cover in the 280. Did that match the one that came off?
    I ordered from GLS without measuring as the website specifically said it was for my boat but it was a couple feet short 🤬
    edited October 2020
  • Pat310Pat310 Member Posts: 603 ✭✭✭
    @Aqua_Aura fit my windshield perfectly. Took careful measurements.  Emailed company and they sent me a 1” sample
  • YYZRCYYZRC Member Posts: 5,405 ✭✭✭✭✭
    I ordered direct from Taylor Made for $1.17/ft plus a $10 handling charge. Any reason why you went aftermarket?
    When I contacted them online they said they said they no longer made or stocked it. Maybe should have called them directly. Was yours the same size @YYZRC ?
    Mine was for sure a different profile than what you purchased, but not sure of the exact size.  Looks good anyway!
    @Pat310 did you reseal all the screws too?
    I also ordered mine from TaylorMade. When I did the replacement, I resealed the windshield screws.
    @Handymans342 I resealed the screws in the spring along with the port windows and the hull joint chasing a mid-bilge leak which I’m happy to say is fixed
    Very good Pat. Have you done all the snaps too?
    Yes I did. Every screw on the deck I could and re-bedded the hatches as well. Tightened all the rail hardware. Nothing bugs me more then water in my boat.
    Another thing to check is the wiper arm mounts. On my 342 there was a rubber washer under a metal cup secured by a large nut.
    Yup. Got that too. Think I used butyl tape for that
